Injector mystery
Injector mystery
Hi, i have a 98 camaro SS with an STS turbo kit, lucas 42# injectors, boost a pump, and new tune and for some reason my number 6 fuel injector has been spraying on the motor since the install. Ive pulled the injectors and swapped them around, ive changed 0-rings, ive even bought an LS6 manifold and billet fuel rails. Nothing has stopped this leak and i cant figure out why. Has anyone had this issue or have a clue to the cause? any help would be greatly appreciated!
yea i did that, as a matter of fact i moved the injectors from one location to the other without switching the o-rings and its still leaked in the same spot. then i still ended up replacing all those with brand new o-rings. still leaks on the #6.
