Head Studs or Bolts?
Old 09-11-2003, 01:15 PM
Formerly 4mulaJoe
LS1x2's Avatar
Default Head Studs or Bolts?
So what is the consensus now? I remember alot of people recommending the use of ARP head studs at one point. Then a few people had problems. What does everyone think about the ARP studs vs ARP bolts?
Old 09-11-2003, 01:22 PM
LS1Tech Sponsor
Slowhawk's Avatar
Default Re: Head Studs or Bolts?
I alway's uae the ARP studs on customers cars.
Old 09-11-2003, 07:05 PM
2001CamaroGuy's Avatar
I have ARP head studs in my motor (will install main studs when I rebuild)....
its also the only way I will work on anyone elses car also (if I'm helping with H/C swap....)...GM bolts are too much work and too weak....
Old 09-11-2003, 07:32 PM
eallanboggs's Avatar
Does using studs as opposed to bolts create a problem with installation and removal of the heads especially adjacent to the firewall at the rear of the heads? On a Dragster or Funny Car you don't have to worry about this, but street cars are different. Is there a clearance issue using studs because of the cowl?
Old 09-11-2003, 08:10 PM
driftwood's Avatar
What do you torque the heads to with the studs since stock bolts are torque to yield?
Old 09-11-2003, 08:20 PM
Pathological Modifier
Ryan K's Avatar
I will always recommend a stud over a bolt. Studs take the wear out of the block. When you are working with an aluminum block even more so.
And yes they do allow you to pull the head in place even in a F-body.
They are torqued to about 70-75 ft-lbs. if I remember correctly, thats for the large studs. The small ones are still at 22 ft-lbs.
Oh and the last time I used factory bolts it took 30 minutes atleast just to torque the things down. That was on an engine stand. In the car its more like a hour, it SUCKS!
Ryan K.
Old 09-11-2003, 08:27 PM
Formerly 4mulaJoe
LS1x2's Avatar
Gotcha. I will be ordering some studs.
Old 09-12-2003, 12:58 AM
Just make sure you re-tap the holes in the block before you install the studs or they will not seat correctly.
What you can do (since it’s impossible to find a tap that is long enough to work on our motors) is to take a factory bolt and grind the threads off on two parallel sides. This will make a home-build tap and then you can run it in-and-out a number of times to clean out the holes.
Old 09-12-2003, 09:34 AM
Vents's Avatar
good advise Chris, i've done that several times. studs seem like the only way to go here. im sure that the 12 point VS 6 point arguement may arise here also, but it's more a matter of opinion, i think.
studs > bolts
Old 09-12-2003, 10:55 AM
LawmanSS's Avatar
I'm by no means an expert on fasteners, but how much difference can this make (12 vs. 6)?...I bought the 6 point...they're quite a bit cheaper...FWIW.
Old 09-12-2003, 11:01 AM
Vents's Avatar
i dont see a diffrence, as i am NOT as 12 point fan, in fact im still furious that my rod bolts were 12 points. and those are 16 too many for me. 12 point anything other than bucks = the devil.
Old 09-12-2003, 06:13 PM
12 point nuts/bolt heads are "supposed" to be stronger (less likely to round off) than 6 point because the load of the socket is spread over more area....
Old 09-12-2003, 06:25 PM
Jorday's Avatar
Its a real PITA to torque down the stock head bolts, thats for sure. I'm gonna get the studs next time because of how much time it wastes using the stock bolts.
Jordan
