Lunati Voodoo 60511? Thoughts?
First of all...I'm new here...nuff said.
I've been trying to recommend some good street cams and stuff for people lately and I've been kinda eyeing the Lunati Voodoo series cams I was wondering if you guys had any thoughts on the Voodoo 60511 as a street/DD cam. http://store.summitracing.com/partde...1&autoview=sku
specs are somewhat comparable to other smaller cams (TR220?) but a little more aggressive it seems like any thoughts? anyone used this cam? they also offer a smaller and larger version #s 60510 and 60512 respectively...thanks guys.
Got it and love it new dyno numbers coming on the 18th when i get retuned with my new exhaust and the LS6 intake. Numbers in sig are on a 98 with stock heads, stock crappy LS1 intake and header dumps.
It seems like a mild enough cam to go with stock springs, looks the 2nd mildest out of the 5 Voodoo cam offerings.
http://www.lunatipower.com/ProductGr...?id=288&cid=60
However, I am by far no expert.
This is a good cam, I am running it and putting down 385RWHP and 352RWTQ, using patriot stage 2 heads, Kooks LT's, Ported TB, LS6 intake, with an A4 trans and getting 25mpg highway cruising with 3.73 gears. I wonder what a good set of ported AFR 205's would do with this cam..
I plan on hand porting a set of 806's with some stock exhaust valves and 2.02 intake valves and seeing what numbers I put down, plus I'm hoping for some solid low to mid 11's at the track for next season as well.
