rod bolt install
rod bolt install
i am in the middle of a build and have a rod bolt question.
I have removed the stock bolts from the rod ends. the new bolts have a metal "seat" that looks like it slides into the rod end. do I need to remove the old "seat" (its a little piece of metal toward the top of the bolt)
i figured out what the problem is. there is a retainer that keeps the bolt from falling out before you bolt it in. when I removed the bolts from the rod bottom caps I had totap the old bolts out with a rubber mallet. the seat I was talking about is some sort of retainer. the new bolts had them so it fit like a charm with the old ones removed. uess i answered my own question. thanks!
