How much should I mill my heads with MS4+Flycuts?
Old 10-10-2008, 01:29 PM
vetteboyc5's Avatar
Default How much should I mill my heads with MS4+Flycuts?
Hey guys Im swaping heads and this is the perfect time to have them milled.
Im running the MS4. with .080 thousandths flycuts. the cam it self clears stock.
I want to bump my compression to 11:1 How much should I mill and keep the stock gaskets, also factoring in the flycuts are probally 1cc each
Old 10-10-2008, 02:03 PM
Super Hulk Smash
JakeFusion's Avatar
If you have .080" flycuts, you just gave yourself an extra .080" to use if you're staying with stock valves and stock gaskets.
Mill depends on what heads you have now. 61cc gives you an 11.1:1 SCR. For every cc you take off the head, you'll need to mill .006".
Old 10-10-2008, 02:41 PM
SOMbitch's Avatar
Running a thinner gasket will give you better quench than milling.
Old 10-11-2008, 06:54 AM
Marc 85Z28's Avatar
What heads?
I'm running 5.3L heads milled to 59cc with a .040" gasket for a compression ratio of about 11.7:1. With the MS4 cam and flycut pistons I have safe clearances.
Old 10-11-2008, 12:47 PM
vetteboyc5's Avatar
Im running 243 ls6 heads, Id prefer to use stock gaskets due to their price. MS4 cam stock valves.
Heres a picture of what my flycuts look like-
How many cc's do the flycuts add? The ls6 heads are 64cc.
Old 10-11-2008, 03:01 PM
1bigcamdls6's Avatar
u sure u wanna go with stock gaskets...and someone interject please if im wrong but ms4 with new heads and stock gaskets...will that last long at high rpm?
Old 10-11-2008, 07:20 PM
vetteboyc5's Avatar
bump... Whats wrong with using stock gaskets?
Old 10-11-2008, 07:28 PM
nuthin is wrong with the gasket itself i was under the impression anytime a very large cam like that was being used or compression is greater than stock mls gaskets should be used
Old 10-11-2008, 08:13 PM
SOMbitch's Avatar
Running a thinner gasket will improve quench(thus reducing possibility of predetonation) as opposed to milling the same. Plus milling reduces flow slightly.
Old 10-11-2008, 08:19 PM
so stock gaskets would be a good thing in this case?
