Katech Delphi to Bosch MAP sensor adapter now available
Here is a solution for your LS3/L92 head/intake manifold swaps. The LS3 uses a Bosch MAP sensor with a different connector and pin-out than the previous Delphi MAP sensor in almost all other LS engines. This adapter allows you to plug-and play the Bosch sensor into the existing harness.
$27.95
