LS7 oil resevoir capacity?
Old 01-13-2009, 09:53 AM
Pete walsh's Avatar
Default LS7 oil resevoir capacity?
How much oil does the oil resevoir hold?
pete
Old 01-13-2009, 05:35 PM
wadd's Avatar
8 quarts I think
Old 01-15-2009, 07:25 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Will the LS7 tank fit inside of an Fbody? I'm going to scout around for a used one if it will. I'm using the rest of the LS7 setup so it would make things simpler.
Old 01-15-2009, 07:39 PM
LS1TECH Sponsor
Katech_Jason's Avatar
pete
Actual volume inside the tank, not sure. (the tank is not filled to the top) Fill capacity of the complete system, 8 quarts.
Old 01-15-2009, 07:40 PM
LS1TECH Sponsor
We put one in a Camaro. We put it where the battery was. We shortened it 3 inches first.
Old 01-15-2009, 08:00 PM
BSmith's Avatar
I would think you could have something fabricated for not too much money. Especially if you have to modify it anyways.
Old 01-16-2009, 11:56 AM
reboot04's Avatar
Peterson has a couple of options that might work for you. I used them for the oil and breather tanks on the '67.
Old 01-16-2009, 08:37 PM
OWN3D BY MY PROF!
That's where I was thinking about as. I'm guessing it wouldn't fit with out the shortening?
Quick Reply: LS7 oil resevoir capacity?
