Has anyone done the L92 + L76 on an LS2???
Yes. Me (there are others).
Most recent dyno sheet and write up here.
https://ls1tech.com/forums/dynamomet...l92-heads.html
LS1Tech Sponsor
I did a set of LS3 Heads on a LS2 GTO 24 tooth crate engine.
Topped it off with a L76 and a Holley 90MM Throttle body.
Hooker 1 3/4" F Body Headers and an electric water pump.
Abaco Digital Mass Air meter.
Small 212/218 Lunati Cam with stock springs.
Small shot of Nitrous with a NOS plate
Let me dig up the dyno sheets. It was on the engine dyno.
Robin
Robin
Maybe I was wrong, could have sworn I'd read the LS3 heads needed a slightly larger bore than the LS2, but it looks like their minimum is 4.00. Well that's good news for me.
I am running the L92/ L76 setup on my LS2. My block was just honed .005 just to clean up the walls a bit, but the L92 heads only need a 4'' bore. You are probably confusing them with the LS7 heads. Anyways my car made 500rwhp with the 6 speed. But now I am running a th400 and the power dropped to 430 rwhp, but it runs 10.5's in the 1/4. So the change was well worth it in my opinion. So yes the L92 heads will bolt onto an LS2.
ok, so where can i get a l76??? I've called everywhere in from (209)-(408)...And they have nothing. They've been aying it ha been discontinued So what intake can I run???
http://media.gm.com/us/powertrain/en...76_G8_GT_n.pdf
since thats what it is in reality.
ok, So I was wondering what I should do while my motor is out...Should I buy: SLP Performance 12292
Wait for GM to sell the L76 and L92
or
Buy a 92mm Fast Intake Manifold buy the heads somewhere else and find all of the other crap that I'll need???
By the way I'm trying to make my car drive by wire...No Cable
or
The L76 is discontinued. The only difference between the two is the way the map sensor mounts.
My '08 G8GT L76 uses the LS3 intake, not the L76 intake.
