Magnaflow y pipe vs flowmaster merge
Old 03-31-2009, 12:59 AM
Fast 95 Z28's Avatar
Default Magnaflow y pipe vs flowmaster merge
Which one would flow better and reduce rasp more?
Old 03-31-2009, 01:01 AM
bongva's Avatar
i think it would have to be the flowmaster merge, a lot of guys are running it on this forum. i have seen them use it on custom setups.
havent seen anybody run the magnaflow y pipe yet.
i was in your boat a couple of months ago. but i decided to get LT's with pacesetter Y pipe, but if i was to do a custom setup it would be the flowmaster merge
Old 03-31-2009, 06:25 PM
TJ
TJ's Avatar
i really like the howe merge y.
they have a 3" inlet and 5" outlet version that cones out real nice.
i have mine cut back a tad and it works great with my 4" bullet.
they are a few dollars more than a flowmaster, but not by much.
Old 04-12-2009, 08:44 AM
9t8z28's Avatar
What is a howe merge y ????
Old 04-12-2009, 09:42 AM
TJ
TJ's Avatar
http://www.howeracing.com/p-7702-y-pipes.aspx
i use the 3"x5" its only 5" the last inch or so to put pipe into. its been cut, and a 4" bullet muffler fits nicely on it.
Old 04-12-2009, 11:46 AM
9t8z28's Avatar
Looks like a nice piece. Is it stainless?
Old 04-12-2009, 12:59 PM
Full-Force's Avatar
It does look nice but stull is not as smooth a transition as the flowmaster.
Basicly, the Flowmaster is as close to a dual as it gets without 2 seperate pipes after the merge because it has both streams of exhaust running parrallel to each other.
Old 04-12-2009, 02:11 PM
TJ
TJ's Avatar
they are not stainless, but have a thick spray of some high temp aluminum on them.
howe also has some sweet x pipes.
Old 04-12-2009, 02:18 PM
TJ
TJ's Avatar
i dont know how much i agree or disagree with that becuase i am not all that up on exhaust flow characteristics.
i will say i swapped the flowmaster merge for a howe several years back before there was a dyno around.
the howe setup sounds COMPLETELY different than the flowmaster one did on the car.
i get all kinds of compliments on how unique the car sounds.
just going on what i think.... the how has a step in the outlet cone much like a merge collector on a header.... they are worth a few hp.
again, this is all redneck guessing.
wish i had dyno results. maybe someone will be bored, or willing enough to test them out.
Quick Reply: Magnaflow y pipe vs flowmaster merge
