Will the L92 fit?
Old 06-15-2009, 09:34 PM
Pavetim's Avatar
Default Will the L92 fit?
Will a L92 intake fit on a 02 trans am? I just mean physical size I know it will fit on the heads. I'm planning on running a raptor hood if that makes any difference. Thanks.
Old 06-16-2009, 03:38 PM
Bring the Noise's Avatar
L92 truck manifold matched up to L92 heads on a 4.00" bore block probably not.
L76 or LS3 manifold matched up to L92 heads on a 4.00" bore block... yes.
L92 or LS3 manifold on LS1 heads and block, not on your life (ports do not match up).
Old 06-16-2009, 09:29 PM
Pavetim's Avatar
Ok let me rephrase this. Will a L92 engine with L92 manifold fit in a trans am. I understand its physically the same as an ls1 but i'm wondering if the added height of the l92 manifold will fit under a trans am hood.
Old 06-17-2009, 10:54 PM
deadhorse66's Avatar
It will not. Same as the GenIII manifolds, it is too tall to clear the wiper cowl.
