Is the LS9/LSA crank the same design as the LS1 crank?
LS1Tech Sponsor
LS9 uses a different bolt pattern for the flywheel on the back end.
The LS9 crank is also setup for dry sump operation meaning it has the same long snout as the LS7 does for the longer dry sump oil pump.
the GEN IV car valley covers are not the same as the gen III. they do not have locations for the knock sensor holes as they are located on the side of the engine. the blocks do not even have locations for the knock sensor bosses in the middle of the valley anymore
Thanks for the info...
I typed valley cover, but meant front engine cover/timing chain cover...
What I'm getting at is... what would you need to do to put an LSA crank pulley/balancer on an LS1 engine (with an LS1 crank), while still having the accessory belt and the A/C belt line up line up with the respective accessories? It looks to me like the LSA engine has the accessories in the same place as the 2007 CTS-V...
So if you had a 2007 CTS-V (6.0L LS2, right?), how much stuff would you have to change to install an LSA crank pulley and have it properly run all of the accessories?
LS1Tech Sponsor
the front cover used is the LS7 style. it is alot diff than an LS2 style being that it has to fit the larger pump inside of it. the cts-v (ls2) uses the same pulley as the vette in the part number aspect and accy offset from the engine.
the LSA uses the same front cover as the LS2 tho. you are really talking about 2 diff engines. the lsa is a wet sump engine. the LS9 is a dry sump. the LS9 uses more flywheel bolts (9) where as the LSA uses the standard 6.
but since the accy are routed different and the water pump is diff, it would take more investigating to present fact to what you are saying. in theory it could work, but there is really one one way to find out.
Thanks a lot for the info John. I didn't realize the LSA was a wet-sump engine - that makes things a lot easier.
You can probably see where I am going with this. I am trying to feel out how practical it would be to drive an LSA supercharger installed on an LS2 engine... or maybe even an LS1 with the right heads.
part numbers for all?
LS1Tech Sponsor
well there is no "ls1" with the right heads because up until now, gm has still not released the small bore L92 heads. unless you look at sleeving i guess.
the LSA uses forged steel crank, PM cracked rods, hyper-e pistons.
of course all of this info can be found at gmpp.com. its not a huge mystery. the pns would not do much good because they are fairly expensive. the price looks to be about $700-800. 58X of course.
LS1Tech Sponsor
forged steel. thats all gm has at this moment. its a GM number. meaning being a reg production crank, its not only just a GMPP #. It is part of the GMPP LSA complete crate engine though. So it is both a gm number and a gmpp number.
its rated at at least 556 HP....lol
LS1Tech Sponsor
Hmm, I never thought about the cam sensor on the rear of the block. After you mentioned it, I looked at a picture of the supercharger unit and it looks like the rear of the unit is largely sectioned out. I wonder if this would provide enough clearance for the cam sensor?
Check out this picture:
Does the gear drive fill that missing section, or does it sit inside the chasis? Even the intercooler is sectioned out as well:
