Victor Jr. with an Elbow
I currently have L92 Heads with the L76 Intake. I'm thinking about converting to a Victor Jr. EFI setup and swapping the Cam to get more power out of it. Also I would be using an Elbow with my 90mm TB to save some space and money.
What would be the best Elbow to go with?
Also, who has the best price on an EFI V Jr. Intake for the L92/LS3 Heads..?
Any ideas on how much power it would gain? Right now I shift at 6500..it has nothing past that. I want to be shifting it at the 7200+ area.
Thanks.
Thanks.
I think the runners on that intake are too short for a hydraulic roller set up and the lack of a decent plenum area will hurt it as well. I think you would actually lose power, alot down low.
But, if you do decide to go with an elbow I would go to intakeelbows.com. Don't go with a low profile elbow, it will kill it.
I just put some new l92 heads on my turbo car. I need another intake so I ordered a Vic Jr with the "low flow" elbow. I figured since I was FI the elbow would not hurt that much.... I guess we will see. I was going for looks any way since my car is not legal for anything faster the 10:00. Is the Edelbrock elbow really that bad?
This is what I run now.
This is prolly the best way to go for sure if your going with this intake merve. You'll want to go SD Tune though, it might not run that great in certain area's, but if you have a good tuner on call then i'm sure making it smooth as possible will not be an issue as long as your cats are hooked up for a closed loop.
You said that your car makes nothing past 6500RPM correct? You'll need a matching cam for this intake and your heads. My car has the Texas Giant Cam slighty modded.... lol Ok it's a ******* monster. With Ls3 heads milled to 68cc, 11:5:1, 92mmTB, and a L76 it made 527/475. It made 450lbz torque at 3000 RPM lol It's one hell of a ride on street tires or nitto's. It chokes air for air after 3850RPM. I'm curious how much harder this modded cam will be pulling with the vic junior and a 4Brrl TB. Elbows have been know for low end kill man. Do the search for it i did my homework. The only elbow you can get away with is aarons ultra low custom elbow.
