D585 and plug wire question
Old 03-10-2010, 11:10 AM
WE3RX7's Avatar
Default D585 and plug wire question
Hey guys/gals,
I'm actually not an LS2 owner, but I'm working on a project for another car and thought who else would be better than the LS community to direct my questions at.
First off, I have a set of D585 coils 19005218, is there any place that has full specs on these coils? Besides the heat sink, can anybody tell me what advantage/disadvantage/differences there may be to the 585 over a 581 or 510c?
Second type of question. I need to make some plug wires that securely fit the d585 coil, do you know the best part # for the coil terminal boots to use?
Much appreciative....
Old 03-10-2010, 02:44 PM
LS1MCSS's Avatar
Read this article and watch the video. Summit has the coil terminal and boots for the wires.
http://www.megamanual.com/seq/coils.htm
Old 03-11-2010, 07:18 AM
SweetS10V8's Avatar
The D585 coils require you to use a lower spark dwell time than other LS coils. If you dont they will start to overheat, but to protect themselves they will just spark early....which isnt good.
I dont know the point at which that happens, but thats what ive been told.
Old 03-11-2010, 04:57 PM
davidws6's Avatar
Default D585's
I've never heard of shorter dwell time on the D585's. You know where any documentation is on this?
I have a set on my TA for over a year and 0 problems with the stock dwell times.
Old 03-11-2010, 09:22 PM
SweetS10V8's Avatar
I searched the parking lot at work today until I found an a set on an '02 tahoe. Then I uploaded the stock tune off the truck with HPTuners, and copied and pasted all the info into my personal tune since I have the D585 coils myslelf.
I have heard about the shorter dwell time more than a few times.....
Old 03-12-2010, 10:00 AM
Unaffliated Racing's Avatar
The shorter dwell time is correct. As stated just check the difference in the tune file for a truck with these coils.
Old 03-12-2010, 11:14 AM
davidws6's Avatar
Default Dwell Time
I did not know this. I'll check the difference between my 4.8 truck tune ( D585's ) and my 00TA ..
Old 03-13-2010, 11:20 AM
SweetS10V8's Avatar
Here is the tune I pulled with D585 coils....Copy and paste anything that different in your tune if using these coils.
File Type: hpt
Old 03-13-2010, 03:33 PM
VIPRETR2's Avatar
Thanks for posting that,
Larry
Old 03-13-2010, 03:44 PM
SweetS10V8's Avatar
No problem, did you see a difference in dwell time settings??
I know mine has been too high for a while now, I like knowing im getting things closer to being correct
Quick Reply: D585 and plug wire question
