spark plug wires that fit headers best + pcv solution - LS1TECH
Thread Tools Search this Thread
Old 06-18-2010, 11:19 PM   #1
Default spark plug wires that fit headers best + pcv solution
looking for spark plug wires with boots that fit my edelbrock headers nicer than the factory wires. i'm looking at these wires, but i want to make sure the boots are as pictured:
http://www.summitracing.com/parts/TAY-72005/
also, what is the part number of the breather you guys are using on your engines? i'm going to add a pcv setup to this engine.
IHEARTLS1 is offline   Reply With Quote
Old 06-19-2010, 07:11 PM   #2
Pop N Wood's Avatar
A lot of guys use this MSD set
http://www.summitracing.com/parts/MSD-32819/
the plug end can be individualy bent to any angle. They are slightly longer than stockers. They can be set up to clear just about anything.
Pop N Wood is offline   Reply With Quote
Old 06-19-2010, 08:27 PM   #3
Jontall's Avatar
I had the Taylor wires and 2 ends came right off when I pulled on the spark plug boots. Most everyone uses MSD.
Jontall is offline   Reply With Quote
Old 06-20-2010, 01:22 AM   #4
I have those on mine.
69cutlassrkt is offline   Reply With Quote
Old 06-22-2010, 04:06 PM   #5
Jon@Texas-Speed's Avatar
We us a LOT of MSD. Seem to have better quality. I've heard too many stories of other brands falling apart!
Jon
Jon@Texas-Speed is offline   Reply With Quote
Old 06-29-2010, 02:09 PM   #6
Randy WS6's Avatar
MSD 8.5's here...
Randy WS6 is offline   Reply With Quote
Old 06-30-2010, 02:31 AM   #7
whats the part number on that little PCV breather filter you guys are using?
Old 07-03-2010, 02:08 AM   #8
bump. i need a breather that will fit on the tube on the passenger's side valve cover.
Related Topics
Thread Thread Starter Forum Replies Last Post
Did I buy the wrong spark plug wires? Matt Klinger Generation III Internal Engine 5 11-09-2016 04:51 PM
Spark Plug wires and 1 7/8 Headers Genhero Generation III External Engine 3 06-04-2016 02:15 PM
Angled Spark Plug Wires Rangersltw Generation III External Engine 8 03-21-2012 11:25 AM
spark plug boots and wires touching headers jerm4472 Generation III External Engine 5 12-19-2011 07:43 AM
spark plug boot end options? wires won't fit right driven87 Forced Induction 11 05-14-2011 10:44 PM
Tags
cables, clear, gm, header, headers, longer, ls1, ls2, msd, plud, plug, spark, stock, truck, wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
