Engine dyno
Old 06-28-2010, 05:10 AM
Gaz05's Avatar
Default Engine dyno
A question for the dyno shops........ I am about to dyno my ls7, havent dyno'ed one of these before, was going to run a short belt around the damper and waterpump like I do on most engines, BUT.. the water pump runs opposite to the crank on these engines, just wondering how you guys set the waterpump up without putting all the accessories on or just let it turn the opposite way for the dyno pulls... Thanks Gaz.
Old 06-28-2010, 06:30 AM
SweetS10V8's Avatar
Two Idler pullies/tensioners, one on each side of the water pump will spin it the correct way and is how I do it.
Old 06-28-2010, 06:31 AM
bww3588's Avatar
do not run it backwards. at least put the alternator on and run a belt from there and just bypass the PS pump. or find someone who has an electric water pump and borrow it.
Old 06-28-2010, 10:11 AM
Jon@Texas-Speed's Avatar
We run our engine dyno w/ and electric pump. Makes it a lot easier to deal with.
Jon
Old 06-29-2010, 05:01 AM
Gaz05's Avatar
Thanks for that guys, the electric water pump would be good, think I can get my hands on one of them....... thanks, Gaz
Quick Reply: Engine dyno
