Windage tray question
Old 09-10-2010, 04:23 PM
srh3trinity's Avatar
Default Windage tray question
I am doing an LY6 swap into a 1974 Firebird. I have an LS1 Fbody oil pan that I intend to use for clearance issues. I don't have a windage tray for the pan. Should I just buy a stock Fbody windage tray or has anybody used this pan from Milodon: http://www.jegs.com/i/Milodon/697/32150/10002/-1?CT=999
Any benefit or drawback to using this tray? Will it work with a stock pan? This is a cheaper option than the stock trays I have seen. I appreciate the input.
Old 09-10-2010, 05:21 PM
nysbadmk8's Avatar
You wont see any power gains from it.. but its not a bad piece.
Old 09-12-2010, 11:38 AM
I wouldn't expect to pick up any power gains from a windage tray. I was more interested to see if this pan will fit and if anybody has had any clearance issues or experience with it.
Old 09-29-2010, 04:35 PM
Chris10an's Avatar
Default It's OK
The old F body should do the job. Done this many times
Old 10-03-2010, 09:24 PM
rem308winvtr's Avatar
use the stock f body one it is fine
Quick Reply: Windage tray question
