Broke manifold bolt in alum head of 6.0
Old 10-31-2011, 04:08 PM
crazygn's Avatar
Default Broke manifold bolt in alum head of 6.0
I was putting headers on my h2 hummer and the pass side 2nd from the back bolt broke off. The bolt is busted off flush with the head and in a point so I can drill it. Any ideas is there a way to drill and tap a hole right next to this one. I can't pull the head it's my driver
Old 10-31-2011, 08:13 PM
S10xGN's Avatar
Your post reads like it's accessible, but if you can't get to it just go w/o it...
Old 10-31-2011, 08:52 PM
dschmittie1's Avatar
Common problem on the 6.0s in the trucks. They typically come out very easily though. I have already before unbolted the cab/body mounts and lifted the body to gain access to removing the broken bolt with out removing the head
Old 11-01-2011, 02:48 AM
2efnfast's Avatar
Maybe I read this wrong, but you arn't asking if you can make a NEW hole in the head and drill/tap into it, are you?
Old 11-01-2011, 03:06 AM
COSTIGAN86's Avatar
I'e repaired 100s of these (work at a dealer) and never had to pull the head or lift the body. Build up a weld on the broke part of the bolt. Don't worry, the weld won't stick to the aluminum head. Weld a nut to the bolt, then easily wrench it back and forth while slowly making progress outward. The nut may break off a few times, just keep welding a new one on. I've never not been able to extract a broken manifold bolt using this method.
Old 09-15-2012, 10:41 AM
vnmous97's Avatar
i just used this method of building up the weld it works great
Old 09-15-2012, 09:09 PM
k_cash1432's Avatar
I had to weld a nut to one of my broken bolts today as well when the easy out broke off in the whole i drilled to take the bolt out took 4 tries but i finnaly got it worked out!
Old 09-15-2012, 09:16 PM
Sumter's Avatar
I have also successfully used this method
Quick Reply: Broke manifold bolt in alum head of 6.0
