Throttle Body Bolts
Old 11-19-2011, 07:20 AM
mbaker3's Avatar
Default Throttle Body Bolts
I just bought a LS3 intake and a FAST 92mm TB for my L92 heads. I have hunted in vendor catalogs everywhere for the throttle body bolts. Where can I buy them?
Old 11-19-2011, 05:20 PM
mbaker3's Avatar
How about the size? I can check with hardware stores if I know the size needed?
Old 11-19-2011, 10:02 PM
SweetS10V8's Avatar
M6 x 1.0 x 25mm. FAST has them.
Old 11-20-2011, 05:41 AM
mbaker3's Avatar
Thanks...I'll contact them monday morning!!!
Old 11-20-2011, 01:26 PM
sicksspeed's Avatar
Default i have bolts
mbaker3, i have gm original used bolts that you can have if you like. if you want these let me know where to mail.
Old 11-20-2011, 05:22 PM
mbaker3's Avatar
Thanks for the offer sicksspeed!!! I actually found them at the local hardware store today! Naturally..........after I had hunted a week on this tube!
Old 11-21-2011, 04:43 AM
sicksspeed's Avatar
No problem. Just be careful buying bolts for other high torque applications. The grade is marked on the end of every quality bolt.
Old 11-21-2011, 01:36 PM
Pocket's Avatar
Nearly all metric bolts sold will be grade 8.8 which is more than enough for 95% of the projects anyone will do. Not like you'll go to the hardware store for head/rod bolts
Old 11-23-2011, 04:59 AM
sicksspeed's Avatar
Quite true pocket. But have u seen any of those unstamped plain bolts? Those are scary. Seen them at big box store. Probably break those tightening a throttle body.
Old 11-23-2011, 07:54 AM
samckitt's Avatar
25mm length ones will not work with a DBW throttle body. I had to find some too & I think I went to Lowes & got the longest they had, Like 50mm or so.
Quick Reply: Throttle Body Bolts
