Edelbrock vic jr and ls3 42lbs injectors theres a problem
Old 11-23-2011, 02:36 AM
sic7camaro's Avatar
Default Edelbrock vic jr and ls3 42lbs injectors theres a problem
I just got my manifold and I was trying to test fit the rails and injectors come to find out the injector are to short.can I just cut down the bracket to make it fit or do I need different injectors?
If I do need different injectors any company or sponsor who.sales a good injectors lmk thanks
Old 11-23-2011, 02:48 AM
DietCoke's Avatar
http://www.summitracing.com/parts/FST-146025-KIT/
Why cant you just drill new mounting holes in those brackets?
Old 11-23-2011, 01:07 PM
sic7camaro's Avatar
I was thinking of just drilling but if I do the rails wouldn't fit in the bracket.what Injectors are u guys using with.the vic jr
Old 11-23-2011, 01:29 PM
1lejohn's Avatar
here is a link to the different sizes and connectors
http://www.fuelairspark.com/WhatsNew...stechsheet.pdf
Old 11-23-2011, 01:33 PM
1lejohn's Avatar
Some more. info. What type are you trying to use the Bosch type (ford green tops) I had a problem with them fitting the L92 manifold with that manifold you need the extended tip type. I bought the Fast type for Ls3 's and my son made custom brackets for a summit rail.
http://www.fuelairspark.com/Products...rs'-0.aspx
Not sure on the Vic jr.
Old 11-23-2011, 04:57 PM
the_merv's Avatar
The Rails are designed to use the standard height LS1 Injector. I'm using LS7 Injectors..I bought that FAST Spacer Kit and it works perfectly to make the short Injectors the normal height of the LS1 Injector.
I dont know how yours is setup, but I ran into the problem of the Stands being too tall for my application, and called Edelbrock to get their shorter Rail Stands. I still had to shim them.
Quick Reply: Edelbrock vic jr and ls3 42lbs injectors theres a problem
