L92-LS3 piston options - LS1TECH
Thread Tools Search this Thread
Old 01-09-2012, 04:51 PM   #1
Default L92-LS3 piston options
I bought an L92 engine that had low compression in one cylinder. The previous owner had a procharger on and for lack of tuning, broke a piston. Aside from a little bit of marks in the combustion chamber, there are a few scratches in that cylinder and to make it right it should be bored out.
I don't want to spend a pile of money on rods and pistons, I searched online and everyone seems to sell pistons for longer rods. I would like a piston that works with the stock rod but is at least 0.020" oversized, a bit more compression wouldn't hurt either. I don't plan on running nitrous or boosting with this engine, does anyone have any ideas for what is available?
PSI GUY is offline   Reply With Quote
Old 01-09-2012, 05:28 PM   #2
Crap, posted in external instead of internal engine. Can someone move this, thanks
Related Topics
Thread Thread Starter Forum Replies Last Post
Quench on LQ4/L92, is .030 too little ? CasperCasper Generation IV Internal Engine 4 06-30-2016 06:02 PM
First ls build! S13 silvia LQ/ls3 head help. Compression ratios Jcollison016 Generation III Internal Engine 6 04-29-2016 04:49 PM
Piston suggestions for my new 6.0L LFA speedshifter Generation IV Internal Engine 5 07-15-2012 02:02 PM
L92 stock piston rings ?????????? carvz Generation IV Internal Engine 1 09-22-2009 06:36 PM
Used Engine prep - L92 - Advice? Lurk Generation IV Internal Engine 6 06-26-2009 04:07 PM
Tags
boost, cheap, compression, cylinder, l92, low, ls3, number, options, oversize, oversized, piston, pistons, vs, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
