MAF and lid for Trans Am LS7 swap - LS1TECH
Thread Tools Search this Thread
Old 02-02-2012, 03:27 PM   #1
man2004's Avatar
Default MAF and lid for Trans Am LS7 swap
We are installing the LS7 in the next few weeks. The LS7 has stock heads, stock intake, Katech Torquer LS7 cam, 1 and 7/8 Kooks long tubes (engine dyno made 619 HP/578 Torque). The car ('98 TA vert) has a rebuilt T56 M6, new drive shaft, new 9" with 411's, SFC's, LCA's, and torque arm. We plan to give it light spray 100-150 shot max. We are considering speed density tuning. But, I am concerned about the temp fluctuations in South FL. And, I do not have a stock LS7 MAF. So, I am favoring using an aftermarket 100mm MAF. What MAF should I run with the LS7 (TSP vs. Lingenfelter)? Also, how can I get more air into this set up? Is it worth cutting up the front end to route more air into the MAF. I know most cars with smaller cubes (LS1) just have a FTP or SLP lid. But, with the 427, is it worth trying to get more air from below (Blackwing, SS, Chris1313, etc) or even a custom CAI through the fogs or cut center section?
man2004 is offline   Reply With Quote
Old 02-02-2012, 03:50 PM   #2
Blk98Vert's Avatar
The 104 lid will be more than enough. You can add a ram air kit to help when you race if you want to
Blk98Vert is offline   Reply With Quote
Old 02-02-2012, 04:20 PM   #3
man2004's Avatar
Quote:
Cool. Thanks!!! Maybe we should start a black on black 98 TA vert club! Lol
Old 02-02-2012, 04:25 PM   #4
man2004's Avatar
What MAF are most guys running in a TA with a 427?
Old 02-02-2012, 09:33 PM   #5
Will you be running this car at the track? I have 2000 Formula with a 427 but have TFS 235s. I'd love to see how are cars compare (Ls7 heads versus TFS 235s). When I built mine I wasn't sure which heads to go with. Good luck.
Bill00Formula is offline   Reply With Quote
Old 02-02-2012, 11:13 PM   #6
Blk98Vert's Avatar
Sure why not lol, and the TSP MAF seems to be the most popular. Be sure to get a screen from Saxon to make sure the airflow is solid across the sensor
Old 02-03-2012, 03:23 PM   #7
man2004's Avatar
Quote:
I plan to run PBIR. I would really like to run the milemarker-1 race some time too!
Old 02-06-2012, 08:33 PM   #8
Stock LS7 heads flows 350CFM at 600 lift on the intake and don't know about TFS , 150 shoot is much on that bottom end , The LS7 valves intakes are not that strong to hold up that more power , I seen many of LS7 with stock valves falls and damaged the motor by falling the intake valves , Second thing the pistons are not strong and has weak top , third thing the rods bolts are very light and can't handle that much power of shoot
PONTIAC SLP is offline   Reply With Quote
Old 02-13-2012, 06:28 PM   #9
man2004's Avatar
Quote:
Very good points! We are planning to run it NA at first. Down the road, we might spay. Fortunately, TEC build the engine with aftermarket (Mahle) pistons and rod bolts. I will need to check on the intake valves.
Old 02-13-2012, 07:01 PM   #10
Mike built mine as well in addition to alot of people I know. Surprised you don't have JE pistons. Seems like that was all he used. When do you expect to be up and running?
Old 03-05-2012, 04:26 PM   #11
man2004's Avatar
The car was painted last week. So, the swap begins this week. I think we should be running by April Fools Day!
Related Topics
Thread Thread Starter Forum Replies Last Post
LS6 vs LS7 maf and iat sensor sbwrench PCM Diagnostics & Tuning 3 06-11-2015 07:51 PM
LS7 or 100mm MAF on a LS1 for turbo help D3fiant New LS1 Owners - Newbie Tech 10 02-25-2014 12:47 PM
Need local tuner in South FL. TransAm Florida Members 13 10-31-2013 05:30 AM
quick question on a SD tune vs. a MAF tune. weeble1 PCM Diagnostics & Tuning 19 08-26-2013 02:47 AM
quick question on a SD tune vs. a MAF tune. weeble1 PCM Diagnostics & Tuning 1 08-03-2013 11:32 AM
Tags
427, air, fit, ignition, kit, kits, lid, ls, ls7, maf, ram, run, slip, slp, swap, times, trans
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
