Headers running too hot , please help
Hi , My friend installed his new LS3 engine and put into his 2007 Lumina SS , Well after installing we start up the motor and noticed the both sides headers are running too hot and the color of the headers changed to orange , After that we replaced the seals for injectors and intake and still running same , Car isn't missfiring and the idle is good .
I told my friend maybe you have bad knock sensors or timimg is retarded and has bad spark so what you guys think ?
Thanks in advance
Thanks in advance
i just ran into this problem on an older 350, what type of manifolds are on it? that was the problem with ours, cheap headers=800 degree exhaust gas, swapped headers and went to 350 degrees, just something to check, i replaced manifold and gaskets and carb. before i figured it out.
