Fuel rails for a stock LS3 intake that aren't red?
Does anybody make fuel rails for a stock LS3 intake in a color that isn't red? All I can find for LS3 rails are FAST, Aeromotive and BBK, and they're all red. Everybody else that's making aftermarket rails in natural/black seem to only offer them for FAST intakes and not the stock intakes.
If I have to I could always powdercoat a set of FAST rails, but I'd rather not go through the hassles if I can just find a damned black or natural set to begin with.
__________________ Weekend projects aren't
Currently under the knife, receiving the following:
402 LQ9 Stroker - LS3 heads & Intake - maybe a 150 shot?? - T56 - 9" rear
Probably not the option you want to hear...but oven cleaner actually does a pretty tremendous job of removing anodizing and leaving you with a natural sort of finish.
__________________ 04 gto=408 stroker with SDPC cnc'd ls3 heads,230/240 617/612 cam, pacsetters and catless mids,svede otr cai,85mm maf,stock ls3 intake and Complete Street Performance dyno tune. 506/468 with clutch slipping and valve float due to wrong springs.(new pac rpm series springs are in waiting for a new dyno no.)
We used the Summit ones on my 76 intake. The injector spacing is all the same on all the rails. The mounting tabs and hardware are whats different. My son made custom hold downs for ours. Lowes has some nice metric sized bolts and washers.
__________________ 99 Hugger Orange 1LE Camaro A4
New Combo L-92 Block and Heads 416ci
Built by The Head Shop. The heads are fully ported, L76 intake, custom FTI cam and valve train. Tuned by Flaco.Dyno results 508 hp at 5800.
Thanks to Jerry, Shawn,Ed,Flaco,and Richard.
Those Wilsons look great. Where did you buy them from? According to the part number on the packaging, those are the rails for ls1/ls6 intake manifolds. I don't think those will work with the LS3 manifold without making my own mounting brackets.
I found the Mast rails at Pace, but they were shown as "discontinued". I emailed Pace and their response said that Mast no longer sells fuel rails.
I emailed Mast to find out if they're still available or not, but I haven't heard back yet.
I ordered them from Summit and yes they sent the wrong ones. The only difference is the mounting tabs, the rails are the same. So they just sent me the new mounting tabs and everything worked out fine.
__________________ 2006 GTO, PRC 215 cnc heads, Torquer V3, Kooks
1 7/8, no cats. 450RWHP. Looking for FAST intake!
