DIY Flywheel Holder
Old 03-14-2012, 01:05 PM
-TheBandit-'s Avatar
Lightbulb DIY Flywheel Holder
I've been wanting to make some kind of flywheel holder because I know cranking down the VVT cam phaser bolt is going to take a lot of umph, not to mention R&R of the balancer bolt is always difficult. There is a great tool out there from Kent Moore / SPX Specialty Tools J-42386-A that bolts to the starter flange area and holds the flywheel with interfacing teeth. It runs about $80 new. Here's a picture:
I've been keeping my eyes peeled for a used one for a while, but nothing has come up. So I've decided to go ahead and make one. I started with a piece of 1/4" steel scrap and traced the teeth of the flywheel against it. Then I made a bunch of cuts with a thick cutoff wheel as shown.
With a bit of trimming I had a whole bunch of teeth. As you can see mytooth spacing was anything but perfect, so I cut it down to just a few teeth and trimmed to fit. Here is what I ended up with.
Using bits and pieces of scrap, I cut a bridge between two pieces of tube and tacked it together while bolted to the engine. Then I welded it, bolted it back up and tacked another piece to hold my set of teeth. I wish the pictures turned out better - I'm proud of the monster I've created. Yeah it's UGLY, but the tooth engagement is pretty darn good and I think it will serve it's purpose well.
This took me about 4 hours to make from some scrap metal I had laying around from other projects. The Kent Moore tool is certainly worth the money, but this is another way to get the job done if you're on a budget.
Hope it helps someone!
Old 03-14-2012, 07:39 PM
S10xGN's Avatar
I love making stuff with scraps, and enjoy looking at other peep's homemade stuff! Nice job!
Old 03-19-2012, 10:45 AM
thenovaproject's Avatar
USDA prime American ingenuity!!!! Nice work
Old 03-19-2012, 10:48 AM
My .02 cents on a easier way?? Cut a portion of the ring gear off of junkyard a flex plate heat and beat other direction weld accordingly??
Old 03-22-2012, 01:13 PM
welldonecj7's Avatar
Nice work I enjoy trying to build stuff like this and its cool to see other peoples ideas
Old 03-23-2012, 01:14 AM
01ssreda4's Avatar
Nice job....
Old 03-26-2012, 08:29 AM
L92Firebird's Avatar
I took a slightly easier route. Piece of an old sbc flexplate from junk pile. Welded to angle iron and drilled for starter bolts. Works fine even though curved "wrong" way.
Old 05-01-2012, 10:14 AM
Nice work. I would have done the same if I had an old flexplate laying around.
This is one of those tools where I don't know how I lived without it before.
Old 06-29-2012, 10:42 PM
Came across this thread for those who don't want to make it yourself, I'd say it's worth the money:
https://ls1tech.com/forums/parts-cla...e-holders.html
Old 06-29-2012, 11:02 PM
My6speedZ's Avatar
Like seeing stuff like this, good job
Old 10-23-2016, 11:33 PM
vette36552's Avatar
Default Dimensions
Can you please post some dimensions of this holder or a drawing . I am trying to make one but need the exact dimensions.
Thanks
Old 10-24-2016, 03:52 AM
Gray86hatch's Avatar
$29 shipped.
http://m.ebay.com/itm/Speed-2800-LS1-LS2-LS3-LS6-LSX-Flywheel-Flexplate-Holder-Locking-Tool-USA-Made-/191755290967?nav=SEARCH
Quick Reply: DIY Flywheel Holder
