Steam vent passage plugged on PRC repl. head?! - LS1TECH
Thread Tools Search this Thread
Old 03-18-2012, 10:12 PM   #1
kballs's Avatar
Default Steam vent passage plugged on PRC repl. head?!
I got a single casting from PRC to replace a damaged one, and the hole is plugged with some sort of plug. The threaded hole is still there, but the water passage is plugged off. Should I not worry about it or try to get it opened up? I bolted the heads on already so it's facing the front where it's plugged. Looks like you can drill it, I rwead one post where a guy said he drilled it, but it looks a bit sketchy.
kballs is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Ls7 head rear steam vent maroonls1z Generation IV Internal Engine 2 03-02-2015 07:41 PM
lq4 and bellhousing bolt holes forcd ind Conversions & Hybrids 33 09-22-2011 07:48 PM
So today I drilled through my head shrike General Maintenance & Repairs 16 12-02-2010 12:58 PM
LS3 head rear coolant passage... ss.slp.ls1 Generation IV Internal Engine 1 11-02-2009 01:39 PM
Looking for cylinder head coolant passage plug. Zedzag Conversions & Hybrids 7 09-25-2006 03:22 AM
Tags
clogged, head, heads, line, ls1, ls6, ls7, mod, motor, plug, plugged, prc, steam, vent, vents
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
