Headers running too hot , please help
Old 02-20-2012, 06:53 PM
PONTIAC SLP's Avatar
Default Headers running too hot , please help
Hi , My friend installed his new LS3 engine and put into his 2007 Lumina SS , Well after installing we start up the motor and noticed the both sides headers are running too hot and the color of the headers changed to orange , After that we replaced the seals for injectors and intake and still running same , Car isn't missfiring and the idle is good .
I told my friend maybe you have bad knock sensors or timimg is retarded and has bad spark so what you guys think ?
Thanks in advance
Old 02-20-2012, 07:16 PM
gs462's Avatar
Glowing headers are usually a sign that the motor is too lean was this motor tuned??
Old 02-20-2012, 07:19 PM
No yet he didn't tuned .
Old 02-20-2012, 07:30 PM
gs462's Avatar
I wouldnt run the car too much or drive it till he gets it tuned you may damage something.
Old 02-20-2012, 07:36 PM
mbaker3's Avatar
Could be too lean or too retarded timing. It might still be burning fuel in the exhaust.
Old 02-20-2012, 08:49 PM
02_CETA_ws6's Avatar
i just ran into this problem on an older 350, what type of manifolds are on it? that was the problem with ours, cheap headers=800 degree exhaust gas, swapped headers and went to 350 degrees, just something to check, i replaced manifold and gaskets and carb. before i figured it out.
Old 02-21-2012, 07:00 AM
Old Geezer's Avatar
Huh???
Old 02-21-2012, 09:38 AM
disc0monkey's Avatar
wheres the timing set at?
Old 02-22-2012, 08:14 PM
Originally Posted by Old Geezer
Huh???
if your responding to my post....... sounds crazy but that was the problem.
Old 03-13-2012, 11:00 PM
Ballzee's Avatar
+1 here
Old 03-22-2012, 10:50 PM
2kblackgtp's Avatar
I'd go with too lean as well, get that thing tuned
Old 03-23-2012, 07:13 AM
redtan's Avatar
Did you put this LS3 engine with its own computer in the Lumina? Or did you just pop it in there with the stock Lumina computer?
Quick Reply: Headers running too hot , please help
