Who makes a cable driven throttle body for ls3????
buy a nick williams 92mm.... hands down best throttle body company out there
http://www.ws6project.com/user_stor/...throttle-body/
You can use a 102mm TB, but honestly there may be some issues with smaller CID with it. Sometimes bigger is not always better, and it takes a bit of porting on the TB area to make sure it will fit.
That NW 92 is one of the best out there and WS6 Store is a good place to get them from.
You may have to change a few of the map readings for the LS3 to work correctly. WS6 store sells the adapter as well. He has quite a few things for almost any f body with any type of LS swap in it.
You need an extension harness for the MAP. I got the cable bracket from Speed Inc. and Im using a 90mm Nick Williams. No reason to go bigger because the LS3 manifold opening is 90mm.
