Can these L92 Heads be fixed? ((PICS)) - LS1TECH
Thread Tools Search this Thread
Old 04-28-2012, 07:02 PM   #1
McAllister513's Avatar
Default Can these L92 Heads be fixed? ((PICS))
I am buying a L92 block with 60K to build for my C5. The heads are off the same block but the problem was that it dropped a intake valve and damaged the piston and chamber. So they just changed out the motor. The damage did not get into the valve seat at all.
So I need to know if it would be easier to buy a used set or fix the one damaged head and run them. They will not be ported just cleaned up.
McAllister513 is offline   Reply With Quote
Old 04-28-2012, 07:04 PM   #2
From the pictures I would say so. I have seen a lot worse than that get repaired. Next question is the cost involved repairing the old head or getting a new one.
1989GTA is offline   Reply With Quote
Old 04-28-2012, 07:13 PM   #3
3.8redbird's Avatar
A piston break apart?
Those don't look to be ported so may be cheaper just to grab another than repair.
3.8redbird is offline   Reply With Quote
Old 04-28-2012, 10:07 PM   #4
That's my thing. If it cost anymore than $200 to fix I'm better off buying a another set.
Old 04-30-2012, 04:12 AM   #5
NemeSS's Avatar
get another set. sell thos off for whatever can get from em. maybe a vj can fix em and some grinding in the chamber to smooth the rough spots. perhaps someone on a budget can use em.
NemeSS is offline   Reply With Quote
Old 05-01-2012, 01:50 PM   #6
Quick99TransAm's Avatar
I would be interested in buying the set u have to play around with to help off set the cost of new heads you could keep all the hardware just intersted in bare heads.let me know
Quick99TransAm is offline   Reply With Quote
Old 05-01-2012, 01:53 PM   #7
97badass's Avatar
If only one is ruined I have a single one that matches your casting numbers in good shape.
97badass is offline   Reply With Quote
Old 05-01-2012, 04:07 PM   #8
How much? And is it the same casting?
Old 05-01-2012, 07:01 PM   #9
boostit5.3's Avatar
i've seen worse repaired.. might wanna get it sonic checked for cracks
boostit5.3 is offline   Reply With Quote
Tags
break, cracked, craked, engine, head, heads, l92, ls1, pictures, powered, repair, repaired, seats, valve, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
