DBW Cruise Control hook up
I have LS2/4L70 swap. speartech harness with ecm programmed for Cruise control with blue, lt blue , gray wires from harness....also ididit column with their Rostra signal lever CC. Anyone done this install? I cant get it to work? any ideas? followed ididit diagram still not working.......TIA
You'll have to see if the switch is set up for the ford or GM switching. GM closes when the "set" button is pushed. Fords the opposite. When I got mine from Dakota Digital, the only stalk controls were ford style. They did make a dash mounted unit for GM.
https://ls1tech.com/forums/conversio...rol-lever.html
