Vac pump on LS3/7 429 installed! (Vid) - LS1TECH
Thread Tools Search this Thread
Old 05-26-2012, 04:07 PM   #1
DietCoke's Avatar
Default Vac pump on LS3/7 429 installed! (Vid)
GZ Motorsports corvette kit with a little custom work to make it fit a 2010 camaro.
http://www.youtube.com/watch?v=uzpKqE2msUY
Small thing I noticed is that it made the idle super crisp compared to before. Neat.
DietCoke is offline   Reply With Quote
Old 05-26-2012, 04:38 PM   #2
Dietcoke,
So what did your car finally put down on che chassis dyno? I was searching your build on another forum and didn't find it. onlydyno stuff I seen was when you were having rocker problems.
thanks,
Jim
Jimbo1367 is offline   Reply With Quote
Old 05-26-2012, 06:08 PM   #3
DietCoke's Avatar
I haven't been back since the rocker problems because I'm moving cross country in a month. (it still made 581 that day). Probably a tick over 600 now, but will get it retuned @ vengeance on Georgia corn when I get to GA
Old 06-01-2012, 10:26 AM   #4
Looks pretty sweet
Burrhos is offline   Reply With Quote
Old 06-01-2012, 03:04 PM   #5
DC love the mods. Tell me, what made you go to a vaccum pump? Did you have a standard PCV breather on it before? I'm pretty sure they make a free HP but any other pluses and minuses?
flash911 is offline   Reply With Quote
Old 06-01-2012, 07:29 PM   #6
DietCoke's Avatar
Breathers weren't cutting it as it was still pushing the tiniest bit of oil at redline. It was fabbed valve covers with -10 lines to a tank, or a vacuum pump. The pump was only ~$100 more total then nice valve covers, lines, and a tank. Was a no brainer, since its worth a good bit of hp.
Related Topics
Thread Thread Starter Forum Replies Last Post
Comp cams Stroker Cam DietCoke Parts Classifieds 37 02-22-2014 12:45 PM
Fastlane Rollbar DietCoke Gen 5 Camaro Racing Tech, Results 10 10-08-2012 04:58 PM
4l80 ---> 2011 camaro DietCoke Gen 5 Camaro Drivetrain Tech 2 02-26-2012 11:45 AM
Little 2011 Camaro hack and slash for sheet metal intake DietCoke Generation IV External Engine 4 12-06-2011 01:56 PM
Can this LS3 head clean up? sidewayz28 Generation IV Internal Engine 10 10-04-2011 10:41 PM
Tags
2010, 429, 429ci, camaro, guide, gz, install, kit, ls3, ls7, lsx, motorsports, pump, vacum, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
