Why is there coolant leaking here? Video inside - LS1TECH
Thread Tools Search this Thread
Old 05-26-2012, 11:06 PM   #1
konceptracin's Avatar
Default Why is there coolant leaking here? Video inside
So went to help a buddy swap his headers and coolant started to **** out the exhaust stud holes, heads are l92 that just had a valve job done....any ideas?
konceptracin is offline   Reply With Quote
Old 05-26-2012, 11:12 PM   #2
Check out this video on YouTube:
http://www.youtube.com/watch?v=61hov...e_gdata_player
Sent from my iPad
Old 05-26-2012, 11:39 PM   #3
was that before you put a bolt into the hole ?
would say u need a new head
Jablowme is offline   Reply With Quote
Old 05-26-2012, 11:42 PM   #4
Pulled the bolt seen some coolant leak out, pressurized the coolant system to make the video, and it's doing this on both heads
Old 05-26-2012, 11:53 PM   #5
Custom User Title
5w20's Avatar
where the heads checked before doing the valve job?
5w20 is offline   Reply With Quote
Old 05-27-2012, 12:36 AM   #6
Quote:
Yes they were, just had them pretty much cleaned up.... They were working fine with nothing like this happening last year in a turbo tbss
Old 05-30-2012, 12:15 PM   #7
At this point why not try using thread sealer on the bolts and see if it works. Maybe liquid teflon like what g.m. sells in tube. What do you have to loose?
sicksspeed is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
oil/coolant problem BallerCamaro21 LT1-LT4 Modifications 2 04-10-2014 05:22 PM
coolant? MaroonLS1 Western Members 10 12-15-2008 10:48 AM
Low/Check Coolant Light Mexicutioner Pontiac Firebird 1967-2002 12 04-05-2008 01:23 AM
whats the best coolant system stop leak slowscott General Maintenance & Repairs 16 02-12-2008 03:05 PM
Coolant temperature for blown motor? Rickerbucks Northwest Members 7 07-12-2005 09:22 PM
Tags
bolt, bolts, collant, coolant, engine, exhaust, head, inside, leak, leaking, ls1, ls1tech, ls6, ls7, stud, subaru
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
