ls3 stock injector
ls3 stock injector
If I'm completely na but worked heads and a pretty decent size cam my question is will my stock injectors be ok??? Or if I can should I upgrade to the zr1 ls9 injectors which are 52 lb??? Basically my question is what hp are the stock injectors good to and is there any potential gain in upgrading
LS3/LS7 injectors are good well into the 400+ rwhp range. Dont use LS9s, they spray fuel at an angle because the have a different location on the supercharger. So they angle the spray to shoot it back at the valve. When you add these to a standard LS engine, your just going to shoot the fuel into the port wall instead of at the valve.
FAST has LS3/LS7 injectors in 50/65/85 lb/hr, Im sure most of the vendors here have them avaliable!
http://www.fuelairspark.com/Products...rs'-1.aspx
