Swapping LS3 into 4th GEN SS
Curious as to what throttle body I can use with the LS3 intake. I know the stock LS3's are "drive-by wire" rather than a cable. Can I use an LS2 throttle body?
Thanks.
Thanks.
LS1Tech Premium Sponsor
Just keep in mind you'll need to fabricate a bracket to hold that little plastic piece so you can adjust and hold your throttle cable in place....there was no such provision on the LS3 intake!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Motor is in via
www.Premierperformanceut.com
Premier built and installed the motor
-6.0 block
- L92 heads
- LS3 Crank
- LS3 Intake
-Manley I beam rods
-JE Pistons and the list goes on.
It should be on the dyno this week, but I'm not to sure I have the fuel system for the power I'm looking for. I have a single Walbro 255 and 60lb injectors. I'm hoping for around 650RWHP out of my TC78.
-6.0 block
- L92 heads
- LS3 Crank
- LS3 Intake
-Manley I beam rods
