Ported (or stock) L92 Truck Intake VS FAST LsXRT 102
Old 07-02-2012, 04:54 PM
Bowtie502's Avatar
Default Ported (or stock) L92 Truck Intake VS FAST LsXRT 102
Trying to find some flow numbers or dyno results between these two and can't seem to come up with much..
I've seen a lot of the LS3 or the Fast (car intake) vs the OEM L92 intake but haven't been able to find any comparisons between the OEM truck intake (preferably ported) vs the Fast LsXRT 102's
Old 07-02-2012, 05:30 PM
Bowtie502's Avatar
http://www.performancetrucks.net/for...intake-477109/
Fast LS3 vs Ported L92
Still cant find truck vs truck
Old 07-02-2012, 06:16 PM
DietCoke's Avatar
The truck intake is the better of the two 102mm fast intakes, if it will fit your setup.
Old 07-02-2012, 06:18 PM
Bowtie502's Avatar
Yeah, im asking between the two TRUCK intakes, im not going to run a car intake but those are the only comparisons I can find.. im trying to find one between the TRUCK 102 FAST.. and a ported OEM TRUCK intake
Old 07-08-2012, 03:40 PM
MASS seller approved
low2001gmc's Avatar
there is not a fast 102 for l92/ls3 heads. I will be running an ls2 portworks ported l92 intake with my ls3 heads. As is, a truck l92 intake outflows an ls3 intake so better if ported. Fyi.
Old 07-08-2012, 09:45 PM
DietCoke's Avatar
Yes there is, just not a large truck sized one.
Old 09-21-2013, 01:29 AM
MIKE1444's Avatar
I wonder if the LSXRT top shell and runner assembly will swap over to the LS3 bottom pieces.
Maybe we're all better off with a Holley Hi-Ram and intake manifold gaskets that keep the heat transfer down.
Old 09-21-2013, 11:32 AM
man-o-war's Avatar
Mast Motorsports prefers ported truck intake on their L92 416ci 550hp Cyclone marine/airboat setups
Old 10-06-2013, 12:49 AM
studderin's Avatar
I know the LSXRT top fits the LSXR runners (I would use the RT runners), the base is the same. But you right there is no RT LS3 runners
RT cuts down the head flow less then X runner. And a straighter and better taper runner make more power and rpm on the engine.
http://i2.photobucket.com/albums/y11...ps1d8dd16b.jpg
I have not info on the GM L92 truck intake, But I know the cathy port ones are better then the LS1 and LS6. And the LS3 car in not that bad, its not worth getting a fast LS3 unless you spend the money looking for 5whp max. Or have to have some good heads, cubes and rpm to show a gain, but then you should have a better intake anyway.
Old 10-19-2013, 09:31 AM
19wagon63's Avatar
I was wondering the same thing. Thanks for the info.
Old 01-08-2014, 04:45 PM
grocerygetter's Avatar
just curious...if I ran an aftermarket hood on my 2010 camaro (654whp now through stock intake...centri+cam) I may be able to clear the Fast truck intake...I know the regular car fast 102 makes minimal gains even at my level...but it looks like the truck gains real numbers. You guys that have messed with it say its beneficial?
Quick Reply: Ported (or stock) L92 Truck Intake VS FAST LsXRT 102
