LS2 Fuel rail Max HP?? (do I need aftermarket ruel rails?) - LS1TECH
Thread Tools Search this Thread
Old 08-03-2012, 12:19 PM   #1
AlterEgo's Avatar
Default LS2 Fuel rail Max HP?? (do I need aftermarket ruel rails?)
I was wanting to buy a LS2 fuel rail to compliment my LS2 intake for my project. I and shooting for 700 hp. Will the stock LS2 fuel rail get me enough fuel to my injectors or is it too restrictive for that much HP??
What do you guys recommend??
Here is my setup.. 4.8L, low lift cam, dual springs, LS2 intake, 92MM TB. Everything else stock...
AlterEgo is offline   Reply With Quote
Old 08-08-2012, 03:15 AM   #2
bww3588's Avatar
If they can feed a heads/cam Ls2/3 etc, I'm sure they can feed a little 4.8.
bww3588 is offline   Reply With Quote
Old 08-08-2012, 06:20 AM   #3
AlterEgo's Avatar
Sorry about that, I can't believe I forgot to mention that I am goin to run a 76 or an 88mm turbo with 20lbs of boost! Goal is 700 rwhp..... Will that fuel rail handle all that or are some after market fuel rails gonna be required??
Old 08-08-2012, 08:13 AM   #4
Mine has done 700rw at 17lbs of boost on E85 with stock LS1 returnless rails. Ive had it to 22lbs on the street.
LS1NOVA is offline   Reply With Quote
Old 08-08-2012, 12:07 PM   #5
Better get some aftermarket AN8 fuel rails and build a good return fuel system with boost sourced fuel pressure regulator. In this case you will be 100% sure that if there is some issue(s) its not affiliated with fuel system.
Also it will support like 1000 or more hp if you choose some good pump(s)
gto_ua is offline   Reply With Quote
Old 08-09-2012, 08:06 AM   #6
AlterEgo's Avatar
hmmm.. thanks for that info.. so I should be able to use the stock LS2 fuel rail without any issues to begin with...
Old 08-09-2012, 08:08 AM   #7
AlterEgo's Avatar
So depending on how much power I will want to run, will determine what fuel rails I will need... I do like the idea of upgrading to a bigger fuel setup to eliminate problems..... What rails would you or anyone recommend?? (fast?)
Old 08-09-2012, 08:08 AM   #8
Yes. You didnt mention E85 or gas but your good at that level with either.
Old 08-09-2012, 10:20 AM   #9
AlterEgo's Avatar
Quote:
I wanted to run E85 because with my turbo but not sure I want to get the 120 or bigger size injectors just to do so..
Old 08-09-2012, 04:42 PM   #10
You can get to around 750rw on 95lb injectors or even 80lbers with higher base pressure.
Old 08-09-2012, 05:05 PM   #11
AlterEgo's Avatar
That will be with regular gas right not with e85?
Old 08-09-2012, 05:11 PM   #12
No, with E85.
Old 08-09-2012, 05:15 PM   #13
AlterEgo's Avatar
No, with E85.
I read somewhere I would need 120 lb injectors to run e85 maybe even larger
Old 08-09-2012, 05:16 PM   #14
AlterEgo's Avatar
I may need to find more research on how to run e85 and what will be needed...
Old 08-09-2012, 05:22 PM   #15
Figure out your max power goals. If you want to just go overkill for 1000rwhp on E85, Id recommend the following:
FIC 160's hi imp
-10 feed, return, and two -8 vents
Fuel rails of choice with Oring boss fittings (not NPT)
Magnafuel regulator
Magnafuel 4303 pump
750rwhp on E85 is kind of the point where things get expensive. Im just over 700 on E with one external Bosch 044 pump, one 255 Walbro, 95 Delhi injectors on 58 base, Aeromotive 13101 reg, stock LS1 rails, -8 feed, -6 return.
Old 08-09-2012, 05:27 PM   #16
DietCoke's Avatar
At 602rwhp I'm only at 47% duty cycle with 1000s @ 7300 rpm (95 LBs) at 58 psi. You wont need injectors that large. I'd go with 850cc/80lbers for a 700rwhp goal.
DietCoke is offline   Reply With Quote
Old 08-09-2012, 09:30 PM   #17
AlterEgo's Avatar
FIC 160's hi imp
Magnafuel regulator
Magnafuel 4303 pump
I dont think I will need 1000rwhp on my street car. I do not want to make a track only car, thats no fun in my eyes.. I want to be able to drive it several hours away from my house and back without any problems, with plenty of power to play around with if needed..
How much more fuel do you burn running e85 vs running regular pump gas? I really do not want to run an external fuel pump due to overheating issues in stop and go traffic.
Old 08-09-2012, 09:32 PM   #18
AlterEgo's Avatar
Quote:
how much more fuel do u burn running e85 over pump gas??
I still want my rwhp to reach anywhere in the 700 range.. I will be happy with that.. Nothing more...
Old 08-09-2012, 10:17 PM   #19
409CISecondGen's Avatar
http://www.injectordynamics.com/HPCalculator.html
409CISecondGen is offline   Reply With Quote
Old 08-09-2012, 11:55 PM   #20
It's somewhere along the lines on 25-30% more to run E85
Exidous is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
LS2 Intake Manifold with injectors and fuel rail detunedstring Parts Classifieds 1 04-15-2016 07:49 AM
WTB: Intake, rails... Avarookie Parts Wanted 0 12-31-2015 07:04 PM
ls7 fuel rail on ls2 intake Gray86hatch Generation IV External Engine 0 12-07-2013 08:37 AM
LS6 factory fuel rail and injectors Rtzracer Parts Classifieds 0 12-01-2012 09:44 AM
which regator and rails are you running? Gfleck047 Forced Induction 24 10-05-2012 12:50 PM
Tags
120lb, boost, correct, fuel, horsepower, hp, injectors, ls1, ls1tech, ls2, max, pressure, rail, rails, stock, support, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
