L9h water pump pulley - LS1TECH
Thread Tools Search this Thread
Old 08-04-2012, 08:38 AM   #1
Default L9h water pump pulley
Hi Guys
Need your help here.
I have just installed L9H VVT truck engine and having some clearence issues between water pump pulley hitting the spal fan on the radiator.
Can you replace the water pump pulley or do you have to replace the entire water pump
Wherre can i get a flat water pump pulley or water pump with flat pulley
Cheers
JK07 is offline   Reply With Quote
Old 08-04-2012, 10:23 AM   #2
Prorac1's Avatar
I dont know for a fact, but you may want to check into a 2010 camaro L99 or LS3 water pump. IIRC they have a flatter pulley and the same spacing as the truck set up due to the deeper timing cover due to the VVT. Hope this helps, good luck my friend. Eric L
Prorac1 is offline   Reply With Quote
Old 08-05-2012, 09:06 AM   #3
Thanks Eric
Really appreciate ur help. I will start looking for a LS3 pump.
Tags
lightweight, ls1, ls2, ls3, pullet, pulley, pump, removable, removal, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
