coil wires
Old 09-07-2012, 09:28 PM
oldngray's Avatar
Default coil wires
Am going to re-locate my coils and wish to make up my own wires, have all of the necessary parts with the exception of the wire end that fits the coils...anyone know where these are sold
Thanks....
Old 09-07-2012, 10:50 PM
My6speedZ's Avatar
http://www.taylorvertex.com/Products...sparkPlugBoots
http://www.taylorvertex.com/Products...ting?id=226041 - I think these are what your looking for, but the top link shows everything they have. They have them in 10mm too.
Old 09-08-2012, 01:04 PM
oldngray's Avatar
Thanks for the reply, they are on my list to contact, as well as MSD, was hoping to find the people who actually manufacture the part, yet this may be my only source...
Old 09-08-2012, 01:35 PM
victorf's Avatar
I did my own coil relocation and was going to make up my own wires, but I found it way cheaper to get the Katech version instead. Amazing how all the parts added up!
My example:
Old 09-08-2012, 02:08 PM
LS1MCSS's Avatar
You can also order the ends for an LT1 distributor side of the wires. They are the same end parts.
Old 09-08-2012, 11:11 PM
My6speedZ's Avatar
I was thinking you could get them MSD as well but I wasn't able to find anything online, I thought that they had a build your own kit and sold parts unnecessary to building custom wires also. But like you said chances are there are just a few companies that actually manufacture the parts that they use.
Old 09-08-2012, 11:16 PM
My6speedZ's Avatar
Did you grind off the lower mount holes and weld them up?
Old 09-09-2012, 07:46 AM
bigblockb's Avatar
MSD p/n 3304 might be what you're looking for.
Old 09-09-2012, 10:23 AM
slt200mph's Avatar
MSD makes a wire kit for relocation applications. You cut the wires to fit your situation. They even include a crimper tool in the kit. I cannot remember the part number. But it is available.
PS Or you can use a LT1 wires and cut the wires to fit your application. That is what I did back about 2004 when I relocated my coils. I fabricated a kit using mis hardware from home depot and LT1 wires. When I replaced the wires a couple of years ago I used the MSD relocation wires.
Old 09-09-2012, 11:56 AM
victorf's Avatar
Good eyes!!
I saw/grind off mounting bosses, then reamed remaining holes, machined T6 pins .0005" larger to provide press fit, then leveled off. I didn't want to distort valve covers with welding heat!
Old 09-09-2012, 02:25 PM
Gray86hatch's Avatar
Firecore 50 best wires on the market
Rick will make you want ever length you need. Not china crap that MSD uses now.
Tim
Old 09-09-2012, 03:47 PM
My6speedZ's Avatar
Good eyes!!
Ah yes I can see that now, turned out really nice.
And yes if your spending the cash Firecore can't be beaten.
Old 09-10-2012, 01:58 PM
oldngray's Avatar
Thanks for all the input, will check out the Firecore site, and yes, anything MSD that has Streetfire in the name is China, that came straight from a MSD rep.......
Old 09-13-2012, 01:39 PM
oldngray's Avatar
Default coil ends
For those of you who do your own, I found..Kingsborne.com... check them out
Quick Reply: coil wires
