LS3 into 02 SS swap kit-where to get???
I am looking for the incidentals-TB, throttle bracket, various wiring leads, gaskets, ect...is there someone out there with a complete kit already put together? Suggestions and needed parts?
you can make the throttle cable bracket, but if not I can get you in touch with a buddy of mine who can make the Throttle bracket for you, all you got to do is bend some descently thick aluminum and put a notch in it, then 2 holes and utalize the intake bolts to bolt it down. I would use a fast 92 on the ls3 intake, and dont buy the fuel injector adaptors just spice on the ls3 connections and then extend the cam sensor wiring.
