so i was lookong through jegs and...
I was looking through jegs and i came upon weld on headers. As in you weld them to the heads.well currently i have a bolt stuck in the forst hole on the drivers side because i broke it off taking the old manofolds off well i can't get it out and i was wondering if i could have an exhaust shop weld that front section up????? Would that work?
No. I've never heard of weld on headers but I have hear of header kits that you make your own and weld them. Plus the headers would have to be made of aluminum since thats what your heads are made of. Your best bet is to get a bolt extractor kit and remove the bolt that way.
LS1Tech Premium Sponsor
^^Agreed, never seen any that they intended for you to weld to the heads before! Typically they are kits where you have to assemble and weld the tubes/pipes together...but they still bolt to the heads.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
how much of the broken bolt is sticking out of the heads? If there's enough I usually use a dremel to make to flat sides and use a wrench to slowly back the broken bolt out. If that fails I use a good set of flat jawed vise grips. If it's below the mating surface i'd recommend having it professionaly removed. Just my opinion.
