LY6 accessories???
LY6 accessories???
I bought a 07 LY6 to put in my 89 irocz but it came without the front serp pulley setup. I have a chance to buy a complete pulley setup off of a LQ4 for $100 but i want to make sure it will bolt on before i buy it. Im pretty sure it will but I would like someone to verify for me first.
It will bolt on for sure, but it's the placement of the accessories that may give you problems. For example, the front crossmember if you have the compressor that's the low mount. Now, us guys with 60-70s old school cars it doesn't matter because well have tons of room.
The LQ4 FEAD will NOT work. Sure it will bolt on. If you are keep the VVT, the balancer pulleys are spaced out. Hense. the water pump is also spaced out. If you deleted the VVT, yes it will work. The L99 FEAD kit will have the proper pulley alignment.
The net is great for mis information? LOL
lower page1 and on 2nd pg.
https://ls1tech.com/forums/conversio...00-6-0vvt.html
This info is pretty much common knowledge.
I have an ly6 & my original plan was to keep the ly6 water pump, use everything else from an fbody spaced out .75" to match up with the truck pump. But now I'm actually considering Holly's a/c, ps & alt brackets.
