2007 LQ4 DBW to Cable TB conversion?
I have an LQ4 out of a 2007 (classic style) silverado and have L92 heads for it,twin 67mm precisions,90# injectors,Holley Hi-ram and just purchased a 102mm TB for it in cable drive. What all do I need to do to delete the DBW setup??
I plan on having it tuned by George & the gang at Turbo Technology in Tacoma Wa.
Later ecus have no provision for IAC.
If you have a 24x reluctor, you could get an early (411) ecu and harness.
If it's a 58x reluctor, you would need an ecu that has IAC capability and runs a 58x crank reluctor (not sure what that would be). Or get a 24 to 58x converter and use a 24x ecu.
