Induction options for my 408?
Hey guys, I'm building an iron 408 with L92 heads and intake for my 2000 Z/28. I have a Patrick G cam on the way and will be running a nitrous outlet plate kit and PTM 92mm TB. I do not have a MAF, elbow or lid. What do you recommend?
You can run the 85mm MAF, the slp smooth bellows ( it will have to be trimmed to length), and the Fast Toys 92mm lid. It all fit on my car with the L92 intake and Harris plate. Its tight but works well. Stepping up to a Fast 102 and will have to rethink this set up. I'm looking at a 100mm Maf, 100mm lid and some custom hoses.
We offer our TSP 100mm MAF sensor with a billet housing and adapter harness. I personally would recommend the 100mm MAF and Fast Toys 104mm lid to match it.
http://www.texas-speed.com/p-660-tex...ow-sensor.aspx
http://www.texas-speed.com/p-284-fas...-air-lids.aspx
There's alot of options on induction. I like the ls3/7 MAF with a saxonpc honeycomb screen if you are wanting to keep a MAF sensor on the car.
Propper tune is gonna have a fully calibrated SD tune as well as a calibrated MAF but pure SD is also doable. For timing pull I would use the PCM for that. A knowledgeable tuner should know ways of pulling timing on the fly only when nitrous is activated so you can keep your full NA timing off the bottle. ;-)
