Help to HO2S sensors
Hello
I have a problem (((( Check Engine ))) after installing Exaust
After checked using HPT VCM Scanner
Gave me This Code appeared to me
oxygen sensors
[ECM] P0036 - HO2S Heater Control Circuit Bank 1 Sensor 2 (SES) (Pending) (Old) (History) (Current) (Immature)
[ECM] P0054 - HO2S Heater Resistance Bank 1 Sensor 2 (Old) (Current) (Immature)
[ECM] P0056 - HO2S Heater Circuit Bank 2 Sensor 2 (SES) (Pending) (Old) (History) (Current) (Immature)
[ECM] P0060 - HO2S Heater Resistance Bank 2 Sensor 2 (Old) (Current) (Immature)
[ECM] P0140 - HO2S Circuit Insufficient Activity Bank 1 Sensor 2 (SES) (Old) (History) (Current) (Immature)
[ECM] P0141 - HO2S Heater Performance Bank 1 Sensor 2 (SES) (Old) (History) (Current) (Immature)
[ECM] P0160 - HO2S Circuit Insufficient Activity Bank 2 Sensor 2 (SES) (Old) (History) (Current) (Immature)
[ECM] P0161 - HO2S Heater Performance Bank 2 Sensor 2 (SES) (Old) (History) (Current) (Immature)
Better to cancel sensors or re- tuning sensors ?
I want a way tuning oxygen sensors and way turn off oxygen sensors ?[/
Note of the type of car g8 6.0
Please reply and advise me
Thanks
oxygen sensors
Thanks
You should put this is the tuning section. They will be able to help you out. When installing the headers you have to change the values that will set the CEL. Headers don't keep the heat inside like cast manifolds do. The ECM expects to see certain volts/amps and switching after so much time. That's why you are getting insufficient activity and performance.
Hope this helps some. By no means am I a tuner.
https://ls1tech.com/forums/pcm-diagnostics-tuning-7/
There is a sticky at the top with some FAQs. You question will probably be answered there.
