l92 alterator only bracket
I am building a l92 engine for a project I have. The car is a 72 Pontiac Ventura. The car will not have P/S or A/C so its just the alernator. I want to run it on the drivers side up top. Not as high as a truck and most of the aftermarket stuff I have been able to find is a HUGE aluminum bracket that puts the alterator way off to the side. i am running the truck balancer and waterpump however. Would consider changing that if need be. Anyone know of anything like this out there? Thanks
I believe a Corvette runs the alt high. You would have to change the balancer and water pump to get it to line up. First gen CTSV runs alt low and very close to the block also with short water pump and balancer.
