3 inch true duals
Old 02-11-2013, 09:26 AM
98_red_z28's Avatar
Default 3 inch true duals
Started my 3 inch true duals to CME. Doing it myself without a pipe bender. Just going to notch it and bend. Should be interesting. Already have the over the axle bends done. Will post pics later.
Old 02-17-2013, 07:37 PM
KingPin1094's Avatar
Hey you got those pics? I was going to use the TSP rumbler X 3". Just kind of curious how well they can be tucked up there and gain ground clearance.
Old 02-18-2013, 06:33 PM
J_O_E's Avatar
I just hate how tight it gets by the rear.
Old 02-19-2013, 02:27 PM
Im going to dump it before it goes over the rear.
Old 12-04-2014, 02:14 PM
98_red_z28's Avatar
sorry guys, the car got put on the back burner for a good while. I am finally done with the exhaust. I made it to where the entire system can be unbolted and removed off the car without any modifications. I used just basic 3 bolt flanges and put two gaskets in between each bolt together section to be sure it seals off. I used 3 ten foot sticks of 3 inch pipe, 14 flanges, and slp 2 mufflers. I dropped the drivers side down about an inch and a half so it would bang the floor pan. Still have great ground clearance, only scrape on real tall speed bumps. The pictures are posted in order from beginning to end. And excuse the dirtyness of the welds, i took the pictures before i got the flux off.
Attached Thumbnails 3 inch true duals-10671339_10203100082010973_3040674728984951773_n.jpg   3 inch true duals-10411019_10203100082170977_174081121735343799_n.jpg   3 inch true duals-10521369_10203100082410983_5727169715905383818_n.jpg   3 inch true duals-10410870_10203100082650989_1392329494294760100_n.jpg   3 inch true duals-1475832_10203100082770992_2947670858631671180_n.jpg
3 inch true duals-10646715_10203100083050999_3919340120628033068_n.jpg   3 inch true duals-10801918_10203100083331006_1710388168587396335_n.jpg   3 inch true duals-10703917_10203100083531011_5254105859815201555_n.jpg   3 inch true duals-1505595_10203100083891020_9196662048724469192_n.jpg   3 inch true duals-10802039_10203100084451034_8838039820788422340_n.jpg
Old 12-04-2014, 02:16 PM
98_red_z28's Avatar
more pictures
Attached Thumbnails 3 inch true duals-10478545_10203100084051024_8065760272371919056_n.jpg   3 inch true duals-10806249_10203100084851044_6290182715374881825_n.jpg   3 inch true duals-10801899_10203100084651039_3167234284036106289_n.jpg   3 inch true duals-10676257_10203100085051049_1921756937719341213_n.jpg   3 inch true duals-10409072_10203100085251054_4932786997179525857_n.jpg
Old 12-05-2014, 06:05 PM
LPE 403's Avatar
Interesting = understatement
Old 12-08-2014, 10:15 AM
smitty2919's Avatar
Your life would have been so much easier had you just bought some 45, 90, 180 mandrel bent pieces in a kit..
I applaud the work that goes into that because I have done the "notch/pie cut, bend, tack, test fit" for simple things. NO WAY IN HELL would I build a whole exhaust that way.
What do you have for ground clearance? The driver side pipe looks VERY low.
Old 12-10-2014, 12:06 AM
HUMBL57's Avatar
I'm speechless. That was probably very time consuming
Old 12-10-2014, 04:24 AM
Kingsize's Avatar
Very interesting indeed!
Old 12-12-2014, 01:26 PM
manaizzz's Avatar
Maybe the OP is sponsored by a welding shop. I like the effort and the creativity that it took to pull that off.
Old 12-12-2014, 02:47 PM
Chevy Guy's Avatar
Old 12-12-2014, 04:06 PM
TooLateVTEC's Avatar
That looks like dog chit run through a salad shooter....you cant be serious...
Old 12-12-2014, 09:17 PM
Gray86hatch's Avatar
What a mess. Please don't offer your services to others
Old 12-12-2014, 10:09 PM
redtan's Avatar
You actually think that **** looks and flows good? Were you high when you did this?
I applaud the persistence and drive to do **** yourself, but cmon man have some self respect for the car. How hard was it to just buy a whole bunch of mandrel bent pipes and put those together?
Old 12-12-2014, 10:22 PM
midnightbluS10's Avatar
So where is the trans gonna go?
Old 12-12-2014, 11:47 PM
HUMBL57's Avatar
Wow! I got so wrapped up in the insanity of the welds and angles and lack of free flow that I didn't even notice the trans wasn't installed. Can always 'wish it in' as I used to say...
Old 12-13-2014, 08:58 AM
Originally Posted by Chevy Guy
Lmao
Perfect!
Old 12-14-2014, 12:34 PM
SSSTANG#1's Avatar
Is that flux core wire or stick?
Old 12-23-2014, 08:04 AM
98_red_z28's Avatar
Actually pretty good on the ground clearance. Only thing that scrubs is tall speed bumps and that's it
Quick Reply: 3 inch true duals
