Ls3 Budget Build
Old 02-15-2013, 03:58 PM
chrisgonz29
Guest
Posts: n/a
Question Ls3 Budget Build
Gents,
Good afternoon, just wanted your opinion i just bought an ls3 engine and want to get the most HP but at the same time keep it in the budget range i am going to go the turbo route i was told to go with a 74mm or 76mm but what else do you recommend? I am planing on porting the heads and putting ARP studs/bolts on main, rods, and heads. I was told i can push give or take 800hp to the wheels... I will appreciate all your feedback thanks!
Old 02-15-2013, 06:03 PM
chrisgonz29
Guest
Posts: n/a
Any suggestions will be greatly appreciated!
Old 02-16-2013, 06:17 AM
BODUKE's Avatar
I just completed a ls3 swap and theres nothing budget about it lol. What
are your goals street car race car?
Old 02-16-2013, 09:12 AM
pupi305's Avatar
Mostly street but plan on taking it to the track here and there... And ya i know it will start getting pricey but just want to keep it under control if u understand what i mean lol i want to put the necessary parts but keep it as stock as possible. I do want a mild cam to hear a lil chop in the motor even tho i know a turbo cam doesn't chop but i figured the lost of horsepower i got for not using the right cam i cam make up by putting ARP main, rod, and head bolts!
Old 02-16-2013, 09:35 AM
Blackpanther99's Avatar
x2^ lol
Im thinking you are going in the street and strip route? Or at least more street route than strip. When it comes to turbo the most budget build route you can go is doing everything on your own at home, such as doing all the installing yourself and stuff. Are you going with a ebay turbo? Some ebay turbos can meet your HP goals while not spending soo much on a turbo. Check in the parts classifieds, you can always find great prices on stuff such as injectors, turbos, turbo manifolds, etc. Plus at that HP the suspension is a big deal also if you want to put that HP down to the ground
Old 02-16-2013, 11:40 AM
chrisgonz29
Guest
Posts: n/a
Originally Posted by Blackpanther99
x2^ lol
My buddy is a turbo freak so he is going to fab the piping once I buy the car but I'm going with a turbonetics turbo 74mm or 76mm...
Old 02-16-2013, 08:58 PM
Well at least you got the fabrication part knocked down good. What is your budget limit? If you dont mind me asking.
Old 02-17-2013, 12:54 AM
chrisgonz29
Guest
Posts: n/a
Man I'm really hoping no more than 3k
Old 02-17-2013, 05:44 AM
Dyno Junkie's Avatar
Old 02-17-2013, 07:58 AM
Originally Posted by Dyno Junkie
LOL... Thats a crazy tight budget. Fuel system, suspension and turbo kit under $3k is pretty tough to accomplish. Are you just trying to keep it below $3k as far as the turbo and fabrication goes? Or overall? Im sure you can find a used turbo kit at a low price on here for less than $3k with BOV and a wastegate, but then again your buddy might give you a better deal.
What parts do you have at the moment?
Old 02-17-2013, 08:21 AM
jdub38672's Avatar
3k budget on a turbo? Not going to happen, sorry but not going to happen.
Old 02-17-2013, 11:28 AM
chrisgonz29
Guest
Posts: n/a
Well I got the motor already I'm not factoring in that cost and I know the turbo is going to cost me 1k so I figured I have to buy the ARP studs (complete) should run around $600 and a cam lets say $400 and let's say my buddy charges me another $600 to build all up and fab and another $400+ on misc I should stay in a descent budget... Definetly not in a rush to build it.
Old 02-17-2013, 05:19 PM
Seems like a good deal. Pretty tight budget though, lets see what you can do under $3k
Old 02-17-2013, 06:51 PM
chrisgonz29
Guest
Posts: n/a
After that then I got to buy a 4l80e and build that up to spec that's why I got to be on a budget lol
Old 02-18-2013, 03:24 PM
LOL seems like a tough challenge!
Old 02-18-2013, 06:36 PM
J_O_E's Avatar
ughhhhh....horrible budget
Don't forget you need to tune it. I would just do a nice full suspension and bolt on's. Sound awesome, drive great.
Old 02-19-2013, 05:28 AM
chrisgonz29
Guest
Posts: n/a
Tuning part I'm not worried my mechanic does all the tuning himself... Like i said it can go over my budget im just trying to be conservative in order to purchase tranny and other necessary items. I told myself im not going to rush it i just want to build it right!
Old 02-20-2013, 05:04 PM
81cuttysupreme's Avatar
What about fuel system? pump, injectors? like mentioned above ewhat about intercooler bov Westgate? dyno tune? software if your doing your own tuning? if your on a budget why not start n/a?
Old 02-20-2013, 10:36 PM
Just do what you can for that $3k and save up more since you arent in a rush, and do it right the first time
Old 02-21-2013, 03:47 AM
yonerhottlt1's Avatar
LS7 or LS9 cam is a cheap option for a cam upgrade...
Quick Reply: Ls3 Budget Build
