Holley Hi-Ram injector diameter??
Old 02-15-2013, 08:02 PM
DHR Darren's Avatar
Default Holley Hi-Ram injector diameter??
I have a set of smartfire injectors that won't fit my Hi-Ram. The fuel rail sice works well and that fith the manifold bung also but the bottom of the injector is too large. What size injector do I need??
Old 02-18-2013, 04:20 PM
LS1MCSS's Avatar
Straight from the Holley web site. Did you get any instructions with your intake?
NOTE: The EFI versions of the LS HI-Ram intake manifold and fuel rail are designed to accept Bosch Style EV-1 or Magneti Marelli Pico fuel injectors. OE LS fuel injectors may not fit properly in the Hi-Ram EFI intake manifold fuel rail assembly. There is a kit available separately for the LS7 Hi-Ram EFI to allow the use of stock LS7 fuel injectors,
Quick Reply: Holley Hi-Ram injector diameter??
