Need help with part numbers.
Old 02-18-2013, 11:37 PM
slammin sam87's Avatar
Default Need help with part numbers.
Hey guys can you help me out with some GM Ls3 part numbers, And 6 piston CTS-V calipers part number.
I need.
head #
Intake manifold #
Fuel rail #
Throttle body #
CTSV Brembo calipers #
Z06 Clutch and pressure plate #
What else is needed for a Ls3 top end on a Ls2?
Thank you.
Old 02-19-2013, 11:15 PM
Bump, Can someone point me in the right direction.
Old 02-20-2013, 10:46 AM
MIKE93SVT's Avatar
i have some 2010 ls3 vette rails if you want em. 80 shipped, pm me if you want them.
mike
Old 02-23-2013, 09:50 AM
J_O_E's Avatar
Google? GM catalog?
Old 02-23-2013, 11:08 AM
Realcanuk's Avatar
http://lmgtfy.com/?q=gm+part+numbers
Old 02-25-2013, 02:52 PM
Albertan's Avatar
Try this: http://parts.nalleygmc.com/productSearch.aspx
Old 02-25-2013, 08:23 PM
keith102371's Avatar
everything u need should be right here
http://www.fbparts.com/everything_ls.htm
ur best bet on the intake is to keep an eyes on the classifieds here for a complete intake setup, they usually go for around 300-350 but gm does sell the intake as a kit GM part # 12610434
Old 03-01-2013, 07:29 PM
Ryan@BallisticSpeedParts's Avatar
Also for your Ls3 top end you will need 8 Ls3 intake rocker arms #12569167, you can re-use your Ls2 exhaust side rockers. You will also need 2 Ls3 rocker arm pedestals #12600936.
And I agree with Keith...go for a used Ls3 Intake setup, you can get them complete w/ rails and injectors for a lot less than trying to piece one together new.
Quick Reply: Need help with part numbers.
