exhaust for large displacement?
Old 03-06-2013, 03:57 PM
02sslayer's Avatar
Default exhaust for large displacement?
im planning a LS7 441 CI motor for my SS soon. im wanting to know what you guys with large displacement motors are running for exhaust. i have a 3" GMMG catback now and im worried it wont be enough to support 441CI. im thinking of picking up the kooks true duals system. but i dont wana sacrifice ground clearance if i dont have to. well, let me know whats up.
thanks guys
Old 03-06-2013, 10:52 PM
02sslayer's Avatar
anyone?
Old 03-07-2013, 04:04 AM
LPE 403's Avatar
I assume you're going with a min of 1 7/8 header right? For my 460, went Kooks 2" and their TD...
Old 03-07-2013, 06:12 AM
02sslayer's Avatar
indeed i am. im picking up kooks 1 7/8 headers. how is the fit with the 2" headers and the TD's on an fbody?
Old 03-07-2013, 09:51 AM
Grr
Grr's Avatar
for that big of a motor 2" primary and kooks TDs are the only setup that wont be restrictive
Old 03-07-2013, 10:13 AM
LongIsland63SS409's Avatar
If you upgrade would you be considering selling the GMMG exhaust?
Mike
Old 03-07-2013, 11:42 AM
02sslayer's Avatar
Mike
absolutly
Old 03-07-2013, 12:34 PM
PM me if you decide to go that route.
Thanks,
Mike
Old 03-07-2013, 05:11 PM
LPE 403's Avatar
The headers fit great.....have a UMI K which helped. The exhaust needed some tweaking. 2" headers have 3 1/2" collector and needed the inlet side of the exhaust system opened up to fit. Had separate issues with fitment of the TDs but it all worked out fine.
Old 03-07-2013, 05:35 PM
Blackpanther99's Avatar
You wont have any issues with Kooks True Dual system. Specially with a aftermarket K-Member
Old 03-07-2013, 05:56 PM
LPE 403's Avatar
The exhaust has nothing to do with the type of K. Although the system meets the flow criteria, there are challenges in installing it. I had SEVERAL issues.....
Old 03-07-2013, 07:23 PM
ramairws6's Avatar
Does it really though? Meet the flow criteria that is. I have since wondered if it would choke up my 13:8 to 1 445 or not. I have dual cutouts right now but the weight of all this under there is extreme believe it or not. So i was contemplating the Kooks TD and there doesn't seem to be many results out there
Old 03-07-2013, 07:31 PM
LPE 403's Avatar
Lol....unquantified statement on my part, but we can't get 4" duals under there sooooooo...... Hope to spin mine with and without the exhaust connected in the next month, so we'll see.
Old 03-08-2013, 07:01 PM
kevin kuether's Avatar
Kooks claims it will support 1200 horse power. Only system to have if you don't want dumps and run big cubes. If you have access to a lift it makes the install go pretty well,although s=after a few heat cycles it will need some readjustment.
Old 03-09-2013, 07:34 PM
02sslayer's Avatar
id like to learn more about a 4" exhaust. i wonder which will have more clearance dual 3 or single 4? i bet a 4" is throaty as a pornstar
Old 03-09-2013, 07:42 PM
keith102371's Avatar
I'm doing a 4" single, got the pipe and bends and muffler from summit for less than 200 bucks.
Old 03-09-2013, 09:59 PM
02sslayer's Avatar
let me know how you like it after u install it. let me know how ground clearance is. is your car lowered?
Old 03-10-2013, 01:31 PM
ramairws6's Avatar
Sounds good and i will be excited to here your resuslts as your power is pretty close to mine....
Old 03-11-2013, 05:23 AM
02sslayer's Avatar
thanks for all the info. i bet those 2" collectors are a tight fit. so i guess im picking up some products from kooks unless i decide a 4" single is the way to go......nah! 3" duals will do.
Old 03-11-2013, 05:34 AM
LPE 403's Avatar
No problem. Hope it helps. Headed back underneath for another tweak or two shortly.....hitting the floor somewhere (cat maybe) and have a little clearance issue at the front side of my rear end. Still worth it, IMO....sure is pretty
Quick Reply: exhaust for large displacement?
