lq9/l92 heads?
Old 05-05-2013, 02:18 PM
916montels's Avatar
Default lq9/l92 heads?
new to the the ls game. tried searching for direct info but haven't found it yet. so i was hoping that some one on here could lend a hand. 2002 lq9 escalade motor and wanting to run some l92 heads. so my question is what l92 heads do i have to get and work needs to be done to them to be 11.1 cr?? any help would be great thanks.
Old 05-05-2013, 04:17 PM
the_merv's Avatar
Mill em down and run a thin Head Gasket.
Old 05-05-2013, 04:19 PM
MASS seller approved
low2001gmc's Avatar
l92 heads are casting numbers 5364 on truck motors. l92 or l76 heads are casting number 0823 on car motors. ls3 heads are 0821 on car motors. ls3 heads come with lighter hollow stem intake valves and sodium exhaust valves. you can mill them .030 or .035 to achieve 11:1 cr or better yet mill .015 and use cometic .040 gaskets which will help with quench and help prevent detonation and still achieve 11:1.
Old 05-06-2013, 01:51 PM
916montels's Avatar
Thanks for the info. which heads do you think I should look for
Old 05-06-2013, 02:16 PM
916montels's Avatar
And is there anything that you recommend me doing to the heads before installing them as far as porting them and so fourth.
Old 05-06-2013, 05:28 PM
the_merv's Avatar
The castings are the same, it's the Valves...the car castings will have the lighter Valves as mentioned.
You can port them, they do flow alot tho.
Old 05-06-2013, 11:22 PM
916montels's Avatar
whats a good price on the heads? well my project is a monte carlo, I did the lt1 swap already but now wanting to go ls here a picture of it now
http://s248.photobucket.com/user/95i...e3a6d.jpg.html
Old 05-06-2013, 11:52 PM
the_merv's Avatar
Definately looks like a Gbody..
Old 05-07-2013, 09:36 AM
916montels's Avatar
Yea its a 87 ls
Old 05-08-2013, 12:03 AM
916montels's Avatar
so g8 heads will work also?
Old 05-08-2013, 06:03 PM
the_merv's Avatar
Yup..
Old 05-08-2013, 09:42 PM
916montels's Avatar
I will keep you guys posted on what i get. thanks for the help guys
Old 05-28-2013, 12:42 PM
Zfan's Avatar
My 2008 Pontiac G8 motor has heads stamped 5364 on them.
Quick Reply: lq9/l92 heads?
